my MOT is due ...BUT ...
aziz
Derbyshire
190E Cosworth 2.3 16v and c230k sport w202
HI ...my w202 mot is due on monday ....but im not suer if my will pass because i have afew issue ....
..1st fuel gauge sender unit not working?
.. when i steer wheel is making noise ?
...my driver side window is not going up some times ?
wil PASS... with those problems?...thanx...
Fuel guage not part of MOT
Window not part of MOT
Steering wheel, depends on what's causing the noise...
Fuel gauge and window won't count. As far as the noise the steering wheel is making, is the noise like a horn, and only sounds when you press the steering wheel?
thanx for u replying me ..... yes it when i try to turn it make noise like a horn....
many thanx .....
Could it be the power steering belt making noises when you turn?
or power steering pump-1st thing to check is the fluid level.
thanx for al of u....
