Have up for sale a brand new boxed nakamichi mb-x music bank 6-CD player. Still new in box. Had bought it for my wifes w203 but now looking for 2-DIN DVD/Navigation unit
Included in sale is a single din w203 facelift facia.
Looking for around 500€ shipped (or £430) paypal accepted.
Specs
9 Colour Illumination Option
Detachable Panel
Rotary Volume Encoder
High Resolution 24 Bit D/A Converter
Noise Rejection Shielding
CD Changer Controller
Analog & Digital Inputs
Acoustic Response Compensator
3D Viscous Suspension
Anti-Roll Suspension
Selectable 1, 2 or 5 Volts Preamplifier Output
Specifications
Power Amplifier
Maximum Power Output 40W x 4 (4 Ω)
Frequency Response (Pre Out) 15-30,000 Hz ± 1dB
Total Harmonic Distortion 0.1% (4 Ω, 1 kHz, 5W x 4)
CDC Input Level / Impendance 0.5 V/10 k Ω
Preamplifier Section
Frequency Response 15-30,0000 Hz ± 2 dB
Total Harmonic Distortion 0.008% (1kHz)
Output Level (Pre Out) 1.0V/2.0V/5.0V (Selectable)
Tone Controls
Bass 20 Hz ± 12 dB
Mid 3 kHz ± 12 dB
Treble 20 kHz ± 12 dB
Loudness 20Hz ± 12 dB
(Volume Level 30)
D/A Converter Section
Frequency Response 20-20,000 Hz
Sampling Frequency 32 kHz/44.1 kHz/48 kHz
(Automatic Switching)
D/A Converter Type 24 Bit DAC
Signal-to-Noise Ratio Better than 95 dB
Dynamic Range Better than 95 dB
Tuner
18 FM/12 AM Presets
Seek & Preset Scan
RDS and AMS – Auto Memory Store
One Touch Memory
FM Tuner Section
Frequency Range
EU 87.5-107.9 MHz in 200 kHz Steps
DM 76.0-90.0 MHz in 100 kHz Steps
Other Area 87.5-108.0 MHz in 50 kHz Steps
Sensitivity 10dBf
Signal-to-Noise Ratio 60dB (Mono)
Stereo Separation 35dB (1kHz)
Antenna Input 75 Ω (Unbalanced)
AM Tuner Section
Frequency Range
EU 530-1,710 kHz in 10 kHz Steps
Other Area 531-1,602 kHz in 9 kHz Steps
Sensitivity 32 dBμ
Signal-to-Noise Ratio 45dB
CD Player Section
Changer Principle 6 Disc MusicBank System
System Compact Disc Digital Audio
Remote Control unit
Principle Infrared Pulse System
Power Supply 3V DC (1.5V x 2)
Dimensions 49(W) x 26(H) x 110(D) mm
Mass Approx. 60g/0.13 lbs/2oz.
(Including Batteries)
Power Source 14.4 V DC (-) Ground (10.8-15.6 V Allowable)
Current Consumption 8.5 A
Installation Dimensions
Main Unit 178(W) x 50(H) x 159.5(D) mm
Outer Dimensions
Main Unit 178(W) x 46(H) x 176.7(D) mm
DAC / Preamp Unit 178(W) x 25(H) x 120(D) mm
Amplifier Block 35(W) x 46(H) x 196.7(D) mm
Mass
Main Unit Approx. 1.3 KG
Poweramp Unit Approx. 0.4 KG
DAC/Preamp Unit Approx. 0.5 KG
Specs
Detachable Panel
Specifications
Power Amplifier
Tone Controls
Bass 20 Hz ± 12 dB
Mid 3 kHz ± 12 dB
(Volume Level 30)
Tuner
18 FM/12 AM Presets
Seek & Preset Scan
One Touch Memory
FM Tuner Section
Frequency Range
Sensitivity 10dBf
AM Tuner Section
Frequency Range
Sensitivity 32 dBμ
CD Player Section
Remote Control unit
Outer Dimensions
Mass
