perdikoyla888
- Jun 24, 2006
Demystifying NTG5S1 ambient lighting => converting from w212 w218 w166 3 colour to w246 12 colour retrofit
Hello everybody,
I want to retrofit 12 colour ambient lighting in a w212 which already has 3 colour ambient lighting using all original parts from w246 12 colour ambient lighting (not aftermarket chinese)
Regarding the ambient lighting from what I understood, they are two different types.
Type A (hardwired without llinbus dedicated ambient lighting control module), 3 colours 8 colours 12 colours
Type B (intelligent software controlled type with linbus dedicated ambient lighting control module) 3 colours 8 colours 12 colours 64 colours etc
Cars with NTG5S1 comand units use Type A
Type A 3 colours uses 3 wires for ambient lighting (or 4 wires for footwell combined ambient with entrance lights)
Type A 12 colours uses 4 wires for ambient lighting (or 5 wires for footwell combined ambient with entrance lights)
Can you please tell me
colours of the wires and where wire1, wire2, wire3, wire4 go in type A 3 colours ambient lighting in the doors and where in the main body.
colours of the wires and where wire1, wire2, wire3, wire4, wire5 go in type A 12 colours ambient lighting in the doors and where in the main body.
I do not want chinese ambient. I am trying to compare w212/w218/w166 original 3 colour ambient with w246 original 12 colour ambient.
There should be a workaround that I am trying to figure out but to find out the workaround we should find the similarities and differences between the two systems.
The only reason I mentioned the chinese before is that they reverse engineered and figured out the differences between 3 colours and 12 colours. If we find this missing part of the puzzle we will find a way to adapt 12 colours ambient lighting with original parts.
There are w212/w218/w166 cars that have retrofitted 12 colour ambient lighting controlled via NTG5S1 comand (irrespective of original or aftermarket the fact remains that they are w212/w218/w166 cars with w212/w218/w166 front sams and door control modules with NTG5S1 comands) so there must be a way around if they managed to control 12 lights from NTG5S1 comand.)
I am prety sure that NTG5S1 comand can be coded for 3 or 12 colours which is one task (if you know how please mention and explain), however the second and most important task is where the ambient wires go in the Type A 3 colours as opposed in the Type A 12 colours as I mentioned above.
Please help!!!
Hello everybody,
Please help!!!
