O/S mirror
  • Thread starter Thread starter Deleted member 138290
  • Start date Start date
D
Guest
I’ve changed both wiring loom and the mirror adjustment control on the O/S door but still the up/ down does not work ??? Everything else on that door is fine, I think... the up/down stopped working about a year ago on the original loom and control hence I’ve changed both hoping to solve the issue but it has not ???? Any idea s please ?
It could be a break in the wire going from the A post to the door, the opening and closing of the door can cause the wires to flex eventually leading to one or more breaking.
Ah thanks for that info ! I hadn’t thought about that bit of wiring
I replaced the complete L/H mirror and it did not work, wiggle the 2 halves of the multi pin plug and it worked.
Can’t think of the multi pin plug ?
The multi pin plug behind the small speaker. The speaker has to be unclipped to get access to 3 torx screws to remove the entire door mirror.
Took small speaker off door and removed mirror to find all the wiring goes into the door on my car ? Couldn’t see a multi plug anywhere and gave the wires a wiggle around but still no up/down on the mirror . I’m wondering if it’s actually the black box at top of the door that all the plugs connect too, sits hidden behind the door panel.
Sorry mine is w211..... thought I had mentioned that.... sorry, my bad !
