I'm too embarrassed to admit that I did exactly the same thing in a V12 E-Type just last week.
rumour has it the brakes are next to useless - so maybe you had the correct pedal after all
I've pressed the brake pedal when wanting to press the clutch - that gives an exciting moment too
And for some reason, when my (right) foot found the clutch rather than the brake, my first thought wasn't that I had the wrong pedal but that the brakes had failed...
As Will says, they probably had.
You trading in your X1/9 for an E type then Mocas?
