interesting issue on the W140. The wastegate is operated by vacuum, switched by a signal from the ECU. So is the EGR valve. There's a second pipe from the EGR which heads up to a little unit on the bulkhead - my guess is this is monitoring the EGR to see that it is in fact operating.
Problem is, sometimes, the wastegate is being held open, so resulting in no boost. It does seem from googling and other forums that if the ECU detects EGR problems, it disables boost by opening the wastegate. Stopping the car and strarting it again mostly seems to reset this, and it then works fine - however, after running a bit it will recur. Current thinking is either the EGR doesn't operate when triggered, causing the low boost mode, or maybe the EGR operates and sticks, also causing an error condition.
Beside removing and checking the EGR, anyone done anything about disabling it? There are several threads on other forums about W210, but it sounds like they have other management systems, as nobody mentions this additional pipe from the EGR.
I could of course bypass the wastegate operating valve and supply it with vaccuum full time, but that could result in over-boosting the engine which likely isn't good for it. Wonder what happens if I bypass the EGR and connect the 2 pipes which attach to it together?
