MBCLKsport
- Jan 31, 2006
- CLK
Hi All,
Looking to replace the engine and transmission mounts on the car, CLK320 cdi.
Genuine MB Parts coming in at around £300.
From reading the forums, I have the following procedure in mind;
1. Car up on ramps
2. Remove engine under tray
3. Remove air boxes
4. Remove serpentine belt
5. Undo top mount 16mm bolts
6. Move the A/C compressor and Alternator out of the way
7. Raise engine using trolley jack (with wood block) from under the oil pan
8. Undo bottom 13mm bolts
9. Remove and replace the mounts one at time
Does that sound about right?
Can I use a normal 16mm socket/spanner or do I need to get the special 16mm offset spanner?
1. Car up on ramps
3. Remove air boxes
