OM642 High Tickover
PaulMason
Teesside
2009 W221 S320 CDi, 2008 W164 ML 320 CDi Sport and 2004 R171 SLK 350
Evening all, my 2008 ML320 CDi (coming up to 126k) has a bit of an oddity. It seems to have a bit of a variable tickover. Sometimes it's 1,100, sometimes 1,000, sometimes it settles at about 750rpm. I initially thought it was the Pro Diesel Chip that it came with (which I removed and surprisingly lost about 2mpg having thought there was no chance it actually did anything) but that didn't change the tickover variability. I am wondering whether the battery is beefy enough/unhealthy (is the ECU making the car tickover a little higher to get some more current into it?) Anyone got any ideas/guidance at what to look at first. It's no real biggie, just a slight annoyance and bugs me and makes it creep a bit harder than it should when queuing. Thanks in advance as always!
When the car is cold (under 12 degs outside) or doing a DPF regen, the car will idle higher
However 1100 is very high.
On an OM642 the idle is usually 750-800 when cold/regen, and 550rpm when warm
Thanks both, looking at some Google results there is some comment about a throttle pedal issue causing similar symptoms so I'll lift the pedal to see if that solves anything and also do a TPS reset (which I assume is the same one a ML as my S)
My first ML had a similar problem, eventually needed a new accelerator pedal , just changed the complete unit, disconnected the old and plugged in the new one , everything was immediately back to normal.
So, lifting the throttle pedal does definitely drop the RPM at tickover, last night from 1,000 to about 820 so still a little high. I suspect it's both a little sticky and also the potentiometer is a bit duff. Next step is to buy a replacement from eBay and see how that goes.
