Greetings, as title suggests, i got a check engine that goes away after a while. Diagnostics say that it is the MAF sensor. The car is sometimes rough on idle and it sometimes jerks when driving (on low rpm). Now, as a preventive maintenance, i would replace the MAF if it wasn't a million euros. Anyways, i brought the car to a mechanic to clean the MAF and other stuff. Light is not gone. After some searching, i came across a suggestion to replace the PCV valve and considering it is not expensive i will do it. There were oil stains under the turbo inlet and around the pcv.
Has anyone have had this problem with the om642 and what are your suggestions to resolve this issue? The mechanic also removed the right MAF sensor from the plastic tube and i can't fuse it now. How do i do this too?
