First the background - 2008 CLS 3.0CDI, bought with 118K on the clock. Ran well but about four times, when it was hot, I got the famous juddering that is normally associated with a fault with the turbo actuator. Took the actuator off, opened it up and cleaned out the black carbon dust that had accumulated from the motor brushes. Having cleaned it I lubed the gear wheels - plastic and metal - with dry PTFE lube. Problem didn't re-occur once.
Then had it mapped and was very happy with the improved performance. However I started to notice when it was hot (after an hour of driving) that the performance was sluggish when you put your foot down. This was beyond the normal turbo lag. It would take longer to build up a full head of steam and not take off in the same way it did when it was not so hot.
So this last weekend I took the actuator off, opened it up, gave it a brief clean - wasn't really dirty even though mileage is now 139K. Decided that maybe the PTFE lube couldn't take the heat so instead I lubed the gears very sparingly with some Molybdenum Di-sulphide grease that I use to lube airguns. When I say sparingly, it was less than the equivalent to two match heads in quantity. This week I have already done 500 miles and the difference in performance is staggering. Even when hot (over two hours running) the mid-range pull is amazing and very quick to kick in - normal turbo lag excepted. It is also consistent at all engine and vehicle speeds that I have tried so far.
Unfortunately I do not know the make of the grease as I purchased it from a guy that makes airgun upgrades and he keeps it secret but it is highly regarded in the airgun world for lubricating. It resists dieseling in airguns so can take heat, is very sticky and I am told it has a high Moly Di-sulphide content. I thought the tiny tub I purchased for £6.00 was expensive but as I only used about 20-30p worth on the actuator gears for the performance gain it was a bargain.
Hope that helps others with actuator issues.
