Om646 timing chain
Durtlocker
Brighton
2007 w639 111 cdi
Hi guys I I having fairly regular code coming up for crankshaft position sensor on my 130 thou mile om646 Vito/sprinter engine , having read some stuff on the internet it’s indicative of a loose timing chain tensioner I just wanted to see if this may be the case from anyone in the know before I take the deep dive and start dismantling the engine to replace the tensioner and possibly the chain , gears as well ?
I don't see how an issue showing the cps is at fault can be connected to the timing chain tensioner?
Before tearing your engine apart, get it properly diagnosed at a Mercedes specialist and get his opinion on the connection between the two.
Getting diagnosis from the internet can be a costly business.
Give Gaz a call at Ace Engineering in Billingshurst. He's a forum member and respected Mercedes specialist.
Ace Engineering - Garage - Billingshurst West Sussex UK
Garage Services in Billingshurst. Ace Engineering. Unit S1a, Rosier Commercial Centre, Billingshurst, West Sussex RH14 9DE Telephone: 01403 785000.
I agree with AMGeed, might happen with a cam sensor though
