Whoa, test test test before you throwing parts at it. Electrical issues should be easy to test, much easier than the such and such signal is implausible type.
Even without any electrical test equipment there are some things you can do.
Unlike most other components injectors are switched on the high and low side. So the problem could be with either. If you had an injector short circuit fault you would disconnect the injector to see if it was the injector or wiring. Similarly with an open circuit I would intentionally disconnect the injector and short out the two pins in the injector plug on the harness. You want that fault code change to a short circuit fault.If it does, there is no problem with harness or ECU. If ECU still reports open circuit that suggests either wiring or ECU.
You replaced the wiring, did that include the female pins in the connectors? If someone has been poking around in there with probes or worse paper clips that can open them out enough that they don't make good contact with the male pins. You shouldn't need I replace them but you do need to check them for pin grip. The injector pins will be the larger ones, so easy to visually check too.
