Adam1998
Can anyone tell me where the oxygen sensor is located on c320 CDI w204 2009 om642,and a replacement part number aswell please thanks.
On the exhaust pipe next to the gearbox sumpCan anyone tell me where the oxygen sensor is located on c320 CDI w204 2009 om642,and a replacement part number aswell please thanks.
Yes I think it is but you will need the car up in the air to get to it with the underpanel offThanks is that on the driver's side
Not a problem thanks mate would u also have a part number handy or replacement
It might be somewhere in this thread I did a few years ago (better double check it for your car though )Not a problem thanks mate would u also have a part number handy or replacement
Yep , they don’t make a great deal of difference on the om642 .fyi I had a code for o2 sensor show up on star on a newly acquired om642 211 several years ago. The car was running well, had just passed an MOT and fuel consumption was good so I decided to leave well alone......seven years and 90,000 miles later it was just the same. The car flew through the emissions tests each year and fuel consumption was exactly where an om642 211 should be.
If you are at all handy you could buy an icarsoft MB2 second hand to look for fault codes.my concern when I was accelerating I would have to put the boot down more on the gas pedal as it feel like there's something clogged that's why I thought O2 sensor would of played a part,as in sending the wrong fuel mixture and now the catalytic converter is clogged and maybe that's why I'm getting a clogged feeling when driving if that's makes sense.
