my 2010 e350 diesel is throwing up error code p0471.
It did this a while back so i changed the pressure sensor https://media.autodoc.de/360_photos/.../h-preview.jpg & it fixed the problem for about 6 months, now 1 month ago the same error has come back.
Ive replaced it yet again but the error will not go , do you think its likely i got a dodgy one ?
do you think its Exhaust back pressure sensor ?
when i clear the codes the car runs fine for 2 or 3 starts , then it goes into what sounds like regen mode with reduced power , then next start up the check engine light comes on & stays on & it seems to stay in regen mode with reduced power until i clear codes again .
thanks
thanks
