MykhailoM
I had a 4.7kOhmm resistor inserted to om642 swirl flap motor actuator plug, after replacing the turbo actuator, removing the 4.7kOhm resistor, plugging the cable into the Swirl motor actuator plug, I have got a CODE: P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 1 (that code wasn`t there before the resistor mode).
Is that code refers to swirl flap motor actuator being faulty or some sort of SENSOR such as Intake Manifold Runner Position Sensor (if one exist for OM642) ?
Thanks a LOT
Thanks a LOT
