Problems with the E200k estate?
zandera
I'm about to collect a 2005 E200k estate with 80,000 on the clock can anyone help with things I should be looking out for and common problems? Many thanks
Make sure everything electrical works, that the self-levelling rear suspension works, and that there is no warning message about the SBC pump. Check the tyres are good and not unevenly worn.
Great thank you, how do I check the suspension?
Thank you, but do you know how to test the suspension?!
Check if the cam chain has been changed , if not get it changed , they do stretch and can cuase damage to valves and chain sprockets .
