Feb 10, 2011 #1 F flt.eng Active Member Joined Oct 20, 2010 Messages 209 Location Nr. Tewkesbury Car E320 avantgared Who are the main manufactures of the VALEO & BHER rads. Do the French make the BHER ran.?
Feb 10, 2011 #2 tagnut Active Member Joined Oct 28, 2010 Messages 391 Location East Yorkshire Car '03 E320 CDI Avantgarde Valeo are French and Behr are German
Feb 10, 2011 #3 K kth286 MB Enthusiast Joined Feb 4, 2003 Messages 2,923 Location Caversham Berks Car E320 Coupe In the uk you get the behr rads via Hella/Behr at Banbury, Oxon. Needs to be ordered via one of their distributors/motor factors.
Feb 11, 2011 #4 OP OP F flt.eng Active Member Joined Oct 20, 2010 Messages 209 Location Nr. Tewkesbury Car E320 avantgared The reason I asked this question is that I have (acording to the crimping) a BHER rad. but it has a small label on the top of the rad saying FRANCE. This is a label you can see at the centre of the rad. Under the rubber seal. Make any sense ?
Feb 11, 2011 #5 K kth286 MB Enthusiast Joined Feb 4, 2003 Messages 2,923 Location Caversham Berks Car E320 Coupe I have a Behr rad on my Merc from the factory. I recently replaced it after 175,000 miles and 15 years. The replacement was obtained from Hella/Behr Banbury via a motor factor and was cheaper than from Merc dealer for this quite expensive item. The new Rad is identical. It was made in South Africa, where there is also a mercedes factory.
