Restraint system malfunction
mikrt
Cardigan
2013 C220 CDI BlueEFFICIENCY AMG Sport Plus 7G-Tronic Plus 4dr
After charging main (original 6 years old) battery and charge low again the next day I bought a new battery.
Key was in pocket with doors closed but unlocked.
Now I have the above error showing as well as red air bag light.
I did drive it for 3 to 4 miles to see if it would clear but it didn't.
I left the new battery on charge overnight when I then discovered that that wasn't fully charged but the errors were still showing this morning so took a lift to work.
I am hoping once I get codes read and cancelled this evening all should be well.
Has anyone else seen this before?
Not so lucky then
Code is B2735-2B squib for the pyro fuse has malfunction.
Anybody have any ideas please?
The SRS sends a "NO-Fire" test current through the igniters in order to check for bad connections.
In case of a car crash, it sends an "ALL-Fire" current. What you could do is locate the igniter
in question and wiggle its connector in order to see if the fault goes away. Unfortunately
a SRS DTC is not automatically resetted once problem is gone. You will have to either get
a Diagnostic tool for yourself or rely on an authorized service center.
WARNING
If you are unfamiliar with working with SRS Do NOT engage yourself with the system!
The energy required to fire an airbag is 0.1mJ equivalent to a pencil dropped on a table from 4" hight.
An electrostatic discharge can cause the airbag to go off. Furtermore, the SRS maintains its own energy reserve
in case of the battery getting damaged in a crash. This reservoir is a bunch of capacitors
that will keep the charge for several minutes after the battery has been disconnected.
When working with SRS, I always wait 30 - 60 minutes and also always wear anti static
protection (a wrist connection tied to the car chassis and a protective earth.)
Thanks for that Uky. Since my last post I've done some searching on other forums and you tube, and favourite at the moment is a pre-fuse in a panel next to the battery. I've either blown a fuse when reconnecting the battery or dislodged something.
I have the same problem, the car worked perfectly first time when I took out the battery to change a fuse in F32, but when I bought a good replacement fuse from Hella and put everything back together, I got this error. Searching on forums, I have found that I have to change the F32 prefuse box, but I have ordered the relay itself and I try it to see how is going. Please keep us updated.
I'll report any updates as they happen, but away for a week before I'm able to do anything. Plan is to remove prefuse panel and check the fuses. I do wonder what I did wrong to get in this position, and I think maybe I connected earth battery side before live, not too sure it makes a difference but that's my theory.
