SpikyMikey
- Nov 4, 2020
- Location
- The Sunny South Coast
- BMW F31 330i LCI M Sport Shadow Edition AMG Black Series Touring
So, having not used my car for a couple of weeks (S204 2013 petrol with the M274 lump), I took it out today in advance of a run round the M25 tomorrow.
About 10 minutes into my trip to fill up, the temperature gauge suddenly shot up to 120 degrees and the rad fan is running like a jet engine.
There's no high temp. warning light on and the car is running fine otherwise. The temperature gauge sits at the normal 80 degrees at idle but as soon as the engine is under load the needle fluctuates randomly between 80 and the readline.
Coolant level is OK (or it was before I set out; I'll check it again later when things have cooled off a bit). No obvious leaks however.
Any bright ideas from the Mercedes collective?
