GazMerc
2013 S204 C220 AMG
Hi all, read a lot about w204 washer issues but cannot see any that fit for mine but please educate me if i have missed the one i need.
Basically on the S204 the screen washer pump has a connection for the rear and one for the front screen.
can anyone point me int eh right direction please?
I have attached a picture of the pump as you can see same as a standard W204 pump but with two outlets, when i switch those outlets over i can make the rear control the front but then no rear and wrong switch so not the correct solution.
all help appreciated
- when I press windscreen washer button the wipers work but not fluid. there is no pump sound.
- when pressing the rear washer the pump that both use spins up and squirts fluid fine
- i have used compressed air and cleaned and blown out all line no blockages
- i have swapped the rear line onto the windscreen and windscreen at the pump end and when i press the rear the rear wiper works as expected and pumps fluid onto the windscreen confirming no blockages.
