Borris1954
- Feb 4, 2013
- Location
- South Bucks
- S204 C 250 CGI BlueEFFICIENCY, R170 SLK 230, B 180d AMG Line
A routine scan with my iCarsoft i980 pulled this code but gave no details. My friend Google says it is an issue with component Y27/9 (Left EGR positioner). So I removed the egr valve which was a little bit stuck in its housing but once out looked remarkably clean. I removed the plastic end cap and there was not much in the way of any carbon debris in the cap or on the mechanicals at all. There seemed to be no sign of the mechanism sticking. Nonetheless I gave everything a through clean with egr cleaner and checked the wiring for damage and used contact cleaner on the connectors before reassembling everything.
The upshot is that the code is still present and cannot be cleared. I have no check engine light and the engine appears to be running fine. I am also sure that when I scanned the engine last year there was no such code showing. So my thoughts are that the solenoid actuator may have died. Is there an easy way to test it? If the valve is permanently closed I guess that maybe why it was actually quite clean. Also in this situation should the engine run ok with no CEL?
Any suggestions welcome.
Sent from my Nexus 7 using Tapatalk
