Alex5000
The ride on my S211 seems pretty firm, switching suspension modes doesn't seem to do anything (although the car will raise and lower ok, it is lower on one side), and a couple of times the 'Airmatic visit workshop' symbol and message would pop up intermittantly.
This prompted me to scan the codes with a basic scanner and I'm getting a host of codes, including B22/3 rear axle level sensor. I have run the car around a few times after clearing the codes, but this one always reappears - I'm also getting codes for:
Interior protection reports a fault in the glass breakage loop
B31 C-AAC multifunction sensor
error in serial communication to rear lamps and interior motion sensor. No response from component N70/2b1 (interior protection sensor) - The interior motion sensor is also listed as 'not activated.'
communication with B33 ata inclination sensor is interupted
outside air temp sensor
There were also a few others I didn't record (I only borrowed the scanner) related to air con, the passenger seat heating element and the tailgate motor, (that last one I have replaced (and it was solved)
I have also noticed the fuel door will not lock, the front A/C display intermittently remains dim, passenger door mirror won't dim, and I have a failed parking sensor (front drivers side immediately next to the numberplate, and the sensor has corrosion on the face, which I believe is causing the PDC to randomly come on). In addition I had a random battery drain one day which has since prompted me to hook up a trickle charger ever since - not ideal.
I list all these in case they are relevant, and I will get to the bottom of all of them, but starting with the airmatic issue, I thought it would be straightforward and just replaced the sensor with a VEMO part from Autodoc. I seem to be in a worse state now as the car feels exactly the same but the airmatic warning illuminates on the dash every time the car is started. The readouts from the old sensor were normal I believe but the code suggests the signal was interupted (which kept the car in safe mode) logging a code each time.
If these faults all point to one module it might explain some/all. I'm going to borrow the scanner again as soon as I can, does the new sensor need to be coded/reset? I've tried to get to the bottom of this with searches, but a bit lost at the moment. Please help if you can
Cheers
Cheers
