pretzelmeister
- Nov 18, 2013
- 2007-facelift E220 Cdi Estate
Hi All.
Hoping someone can help with some ride height & camber / alignment queries please?
I have an W211 / estate - facelift 2007 - WDB211208 - Avantgarde (Code 954) - with self-levelling air suspension at the back (but not airmatic) - and steel springs up front - and am running 16" rims with 225/55 tyres all around.
I have too much negative camber up front.
I believe front camber adjustment bolts will only give up to third/half-degree adjustment - which is not enough.
So suspecting is a ride height issue. (Torque struts, spring control arms, lower ball joints have all been replaced within the last few years / 30k miles, but I believe shocks are original.)
When had rear tyres replaced recently, garage put the car on the alignment rack for me so I could measure ride height:
According to spec, looks like my front ride height is wildly out.
I am pretty sure I have correct springs on the front - 211 spring points (which is in the 206-230 range) so spring 2113210404 (x1 Green + x2 Yellow).
And as the shocks haven't been changed, I am assuming that the spring pads and shocker circlip positions haven't been changed either.
Both of my rear air struts have been replaced with Arnott A-2726s.
Do I have the correct target inclination specs?
Anybody know what the stock ride height is / should be?
If I were to install thicker spring pads up front (or maybe would need to be longer springs - A211 321 05 04s instead of A211 321 04 04s?) , would that sort it - by increasing ride height and reducing negative camber?
What's my next step? - Check front spring pad sizes (I believe can do this 'by feel' for the 'number of bumps'?) - and also check front shock circlip positions?
All help gratefully received - thank you. - Have been munching through tyres much faster than I would like!
