robsterpaterson
Hi all. History - had rear subframe of my 2014 E350 estate checked last year (October) and all was deemed well. Literally just had MOT done at local (non-specialist) garage and no mention of corrosion...apart from a rear brake pipe of course. They changed that by cutting/routing it differently to avoid subframe removal)
I've recently changed both rear airbags and the airlines along with the compressor.
I'd only driven it 10 miles to the MOT station after changing the rear suspension and it all felt fine. However this afternoon driving home from it's MOT it's started 'drifting' to the right under hard acceleration which is noticeable through the steering wheel. Upon lifting off, it seems to snap back which is again noticeable through the steering wheel/****.
I'm going to look for anything the garage may have loosened to do the brake pipe. The wheel nuts are tight and the tyre pressures are fine.
If that yields no joy then I'll call the MOT place on Monday to see if there's anything they may have done.
Worst case scenario I'll pop it back into Mercedes for another 'free health check'.
From what I've said, any ideas??
