S213 Front Passenger Airbag De-activation
Ozboy
W213
I have a 2017 e-class and I would like to carry a 6yo child in the front passenger seat, in a child seat, and the manual indicates that the airbag system will automatically detect this scenario and turn off the airbag without any manual intevention. Have I understood this correctly?
I appreciate its much safer to carry them in the back but this is a one-off treat for a short drive as a reward for good behaviour! Trying my best at parenting 101!!
Not sure specifically about your car, but:
1. In the olden days this was an optional feature called 'child seat recognition system', that if fitted would automatically disable the front passanger airbag when a Mercedes Benz approved ISOFIX child seat is detected.
2. On all MB cars (whether fitted with the optional 'child seat recognition system', or not) there is usually a dashboard light for 'Passanger Airbag off', that lights-up briefly when the ignition is turned on. If your car has this light, then that would be a good way of knowing if the front passanger seat has indeed been disabled (i.e. the light should come on permanently when the child seat is connected).
3. There's a separate feature on all MB cars called 'front passanger seat occupancy sensor' which disables the front passanger airbag when the passanger seat is unoccupied. This works differently to the 'child seat recognition system', and it's operation is seamless in the background i.e. there's no dash light or indication to show if it's on or off. The point is that you can't relay on the child's low weight deactivating the airbag, you need specific indication that the front passanger airbag is indeed decativated, as per (2) above.
4. On a general note, it is not recommended for children under 12 years only (some say 14) to seat in the front passanger seat. If you must sit a child there (with or without child seat), then you should move the front passanger seat as far back as it will go, and recline the backrest away from the dashboard while keeping it flat with the rear of the child seat.
There is no isofix system on the front seat but I do have a couple of airbag related lights which I will check out tomorrow. Thanks
If you can be sure the air bag is deactivated then you go for it. I adored having our daughter up front with me when she was young. Those times chatting away were fab. :thumb:
The child seat recognition only works with a MB seat that contains a transponder.
https://www.mercedes-benz.co.uk/con...ngle-MEDIA.download.tmp/Childseatbrochure.pdf
Not that I plan to have a child in the front seat of my car, but isn't it any child seat that has a transponder?
I'm sure Mercedes would prefer you bought their seat, but I was under the impression that many OEM manufacturers (such as Recaro) include a transponder that works with most cars that have the technology.
