If it was only the ABS and ESP I would say that you have a faulty wheel speed sensor (one of the fronts most probably), but since you also mentioned SRS then I suspect low battery voltage. Can you check the battery voltage? Otherwise, you'll need to take it to an indie with STAR (or invest in an iCarsoft).
