Screens
Wadsy
Norfolk
C250d
Hi, hope someone can help, I have a c class coupe, 2016, is it possible to fit a later larger screen, is it a direct replacement? Thanks.
I guess we're not talking windscreens here?
I think a little additional information/detail might help
You can fit a larger 10.25 inch screen however they aren't original. They are chinese copies of MBUX. They cost from £550 to £700.
Just search in Ebay Mercedes Android Screen. Plenty of videos on youtube also.
As a heads up...If you have any warranty this will become void and if you brick your cars entertainment system whilst fitting it then this could become an expensive fix.
What screen do you have now is it Audio or Comand?
Your 2016 C205 will have either the Audio20 infotainment system with the optional Garmin Map Pilot navigation on SD-Card, of the higher-end COMAND NTG5*2 with the built-in navigation system on internal HDD. The latter will have a bigger screen than the former.
So if you have Audio20, an upgrade to COMAND NTG5*2 infotainment unit with the bigger screen is possible but expensive - contact [email protected] with your VIN for a quote. BTW, they can also fit Apple CarPlay / Android Auto to your car.
If you already have COMAND, then your only option for a bigger screen is a non-MB Chinese 10.25" joby as nas2021 said.
I initially read that too quick. Thought you made a new nickname for me 'joby' hahaaaa
