Seatbeltwarning system
Mogs
Swansea. UK.
2002 E240 Avantgarde
W210 Seatbelt warning
Hi all,
Can anyone help? I have a 2002 W210 E240 2.6 Avantgarde, The problem is that the Seat belt warning system does not work, no light or buzzer, and therefore I suspect the Airbags may not deploy in an accident. The lamp on the cluster is OK and the system works for parking brake, giving both audible and visual alarm.
Mogs
Have you checked the electrics and wiring connections under the drivers and passenger seat?
Hi Brian, thanks for your reply. Yes I have checked under seats and checked for removed fuses etc.
Hi Daniel , Thanks for input, glad to hear Airbags should work.Only had car for three months, system has not worked in that time. I asked the main Dealer if it could be switched off , they said they did not think so.
The car is UK spec Originally purchased from Greenoaks of slough.
Cheers
