I've been researching which model to go for, all engines appear strong. I've seen a 450 that I like. Are there any experts out there who can advise on what I should be on the look out for with this power plant.
Steve
As above, 450 will be very thirsty (low teens). If you can put up with that, just make sure it's not terminally rusty.
Post 80 cars got a 4 speed auto.
Post 86 cars had a lot of changes, not just rustproofing (which means nowt at 20odd years - they all rust).
I hear loads on here about the 300 being much cheaper to run - load of rubbish. Real world you're talking a difference of 2mpg over the 500. They're both massively under stressed and will do mega miles (200k plus). Torque in the 500 is addictive but also a tad wayward in the damp (LSD or not). My advice would be to buy the best body whether it be a 300, 420 or 500.
Check for smoke on start up and overrun (even then it'll probably run for miles if it smokes!)
Check for rust very carefully on the chrome - they rust inside out so even the tinyist speck will be worse than you think and they are eye wateringly expensive to replace.
Oh, and don't buy one of these for balance / handling etc. They drive like a 60's designed heavy barge. Because they are.
129 could be a good buy too, but remember that they rust in some equally awkward places and have a lot more electronics to go wrong (which are horrendously expensive parts wise!) Cheaper to buy a good one though!
Just my 2c worth but, the 129 has always seemed second best to a 124 cabrio.
.... the 129 has always seemed second best to a 124 cabrio. The 124 is just more practical and, to me, ultimately good looking.
The R129 isnt a patch on the R107 in terms of style and comfort.
No the 129 is comfier........but you are missing the point. The 129 is a modern car the 107 is a classic car. I am sure that the R230 is better than the 129 for a blast across Europe......
