Stumped
hog
Ml320 CDI + E350Bluetc Night Edition Estate
Hi I have just fitted new GPS Antenna and nav now works but the SERV button and the MAP button now do not work.
Thanks for any help
Hog
Try a reset, remove fuse for Comand and nav processor.
Hi I take it to reset all you have to do is pull the fuse no3 on my s211 as I did this and still no map or serv button.
Hog
Help!!!!!!!!!!!!!!!!
Bump anyone
4 years ? Still broken ?? Have you disconnected the battery for 5 mins (disconnect earth only (brown wire) ? What is your car (I think you say its a S211).
Richard
Richard
Hi Richard yes done battery disconnect but still the same :-( I have a E280 Cdi S211
My word! Still a problem 4yrs later??
I suspect the button on the COMAND is broken. But it is *very* strange that this occurred at same time as changing the aerial. I assume you have COMAND with Nav Drive in the boot. If it is Audio-50-APS then the antenna would have connected to the head-unit and I guess could have got broken when unit removed ?
Are you anywhere near Lightwater in Surrey ?
R
Yes it is the Audio-50-APS so if button is broken can it be repaired ? I live 10 miles from John O Groats so not really close to you lol
Cheers for your help will give them a try.
hog
