Maurauth
So I'm looking to drop my W204, and from researching the USA sites, the best way seems to be with H&R SuperSports Springs (40-45mm) and replacing the rear shims(pads/rubber things the springs sit in) with 5mm ones so that the car sits on less of a slope.
I was wondering if you guys could give me any advice as to whether these will cause any issues with the standard 17" AMG wheels, and when I uprate to 19" but lower the profile and keep the same offset, if I will have any issues.
I've been told by some places that it will be fine, others have mentioned excessive wear on the dampners, and one place mentioned having to change the camber pads(I think that's what they were called) to prevent wear on the front tyres.
Has anyone used these H&R SuperSports before and if so where did you source them, as other than importing from the USA, the only option seems to be CKS, but they don't specify them as the Super Sports, just as H&Rs that drop 40-45mm. I tried ringing them and asking them to look at the part number on the box/springs but they were less than helpful!
This is the sort of results the USA guys have had with these springs, and nothing else (obviously on larger rims than the 17" AMGs):
