GeoffWestWales
Hi All, MOT due next month so always take it early, new it would fail as need to replace rear reluctor ring to turn off ABS fault but the other fails listes are:
Suspension Arm ball joint excessively worn Nearside front lower (front outer)
Suspension Arm ball joint excessively worn Nearside front lower (rear outer ball joint)
Now its the wording in brackets that has confuesed me I assume by front and rear I assume the front one is on the end of the track control arm?, if so they are around £100 plus, but is the balljoint replacable or do you have to buy the complete arm?
Not done any suspension work on the old girl so not sure of the set up but in the Haynes manual they call what I would call the track control arm, the Torque Strut and the picture is not the best but thats the two balljoints I can see.
