Turning 5G Automatic Transmission Manually E300TD 1999
nigelwu
e320
I want to drain the Torque Converter but to get to the drain plug I need to turn the transmission manually. If I get on the crankshaft bolt should the transmission be in Park or Neutral?
Either park or neutral will work (in gear would too as there's no drive without the engine energising the pump).
Appreciate the answer. Thanks
