Mintyfresh77
I know vibration threads have been done to death and all fingers normally point at engine or trans mount but this doesn't fit the usual criteria so looking for any out of the box thoughts or suggestions (hate that phrase but it's applicable here).
2009 S211 OM646 220 cdi 5spd Auto with currently about 129k on the clock. Great history pre and post sale to me in 2021.
So Transmission oil & filter change done at Merc indy in late 2021 because I had just purchased the car and it hadn't been done yet, then new Lemforder engine and transmission mounts fitted in July 2022 as the car was at 125k on originals and the merc specialist health check had mentioned they were worn. All mounts changed and didn't notice any real difference to be honest but at least they were ticked off the to do list.
By September 2022 I was noticing excessive vibration of the interior plastics and a noise like you would get if an exhaust wasn't fitted properly and vibrating against the underside of the car. Only happens while stationary if you select D or R. When stopped at traffic lights it's so annoying to me that I put it in neutral but here's the thing....this only happens in the first 30 minutes of running the car, get it nice and hot on a run and the problem totally dissappears.
Injectors all replaced (brand new) and various other fuel system components when trying to zero in on a rough idle issue last year but still this problem remains. Now here's something that maybe something or nothing...my wife mentioned it took a few cranks to fire up the other day, hooked up the code reader and it stated a historic EGR 20A3 but when I inspected the EGR last summer it was amazingly clean (non DPF car).
So is this potentially transmission, prop/bearing related or downstream effect of perhaps intake manifold/EGR shenanigans? Or none of the above?
I have been underneath and looked for unwanted contact points between exhaust and body (nada) I loosened all the exhaust fitting bolts and retightened in the hope it hadn't settled since the mounts were done (nada).
I just live with it now but sh/t like this bugs me. I like to know because prevention is better than cure and all that.
