Vito 115cdi not cranking
maddriver
Ely
ML 320 CdI Sport 2008
Hello and welcome.
It's my first post and not good one unfortunately.
I have a problem with my 2004 vito 115cdi.
When I put key in ignition I can hear steering lock operate, all lights come on on the cluster bit there is no crank.
I have checked battery and it has 12.65V.
When I short points on starter solenoid it cranks then.
Any ideas guys?
Thank you.
I have managed to start van with my friend help.
He has turned key to start position and I've shorted terminala on the starter with screwdriver.
This eliminates ignition fault as injectors were activated and van started.
Have you got a clue why is it not startung when key is turned?
Starter solenoid or can it be something different?
Yes looks like. I have replaced starter and still same.
Looks like ignition barrel not sending signal to starter solenoid when key is turned.
But van starts when external power is sent to starter and key turned.
Sounds a pain. Any progress..?
