Gizzardio
Hi
I've had to replace my radiator so I drained coolant from radiator drain plug and the engine block drain plug. Then replaced the rad and filled back up with coolant. My manual and other resources say it's 8.5 litres of coolant in my Type 102 2.3l engine but only 6.5 litres was consumed back before being full at top of the radiator. I've ran the engine to burp it and the flow and return hoses became hot as expected. I did squeeze them a fair bit and bubbles and coolant was coming out of the radiator fill point. The cabin heater matrix also was hot so it's flowing around that circuit too.
So I'm a bit mystified where the 2.5 litres should have gone. I can only think there's a 2.5 litre air lock but where would this be if the hoses are seemingly running hot and feel like there's water with pressure inside.
Finally I ran the engine at idle until the thermostat opened and it held at 88 to 90 degC the whole time according to dashboard gauge. Is there any possibility that the coolant sensor is within an air lock and potentially reading incorrectly and the engine block is actually a lot hotter? This seems unlikely but I'm out of ideas really.
Any help appreciated
