W140s500
- Jan 20, 2012
- Location
- Norfolk
- Mercedes W140 S500L, W124 230 CE plus many more !!
I wonder if I could have a few ideas on this recent niggle I have encountered - first problem in 5 years !
Went to move the car last week and it was not happy trying to start; jump leads were used and it started, but didn't want to rev until warmed up and would die if the throttle was touched. Once up to operating temperature runs as normal and electric fan clutch does work also so all seemed normal .
ABS light illuminated as normal when ignition switched on but does not extinguish.
OVP relay inspected ( no obvious fault ) and also tried another supplied by w140 spares - no different
Battery charging at 14.3 volts
Front ABS sensors visually inspected and cleaned
Both relays on ABS unit swapped from a substitute vehicle - no difference
No obvious harness issue on visual glancing
ABS and engine ECU behind battery visual inspection of terminals - all clean
Recent new plugs, cap, leads and rotor
No misfiring
With an assistant whilst turning the ignition on and off the assistant said they didn't feel any clicking or pulsing from the ABS unit which they did detect when inspecting a similar vehicle which was used to ' borrow ' the relays under the plastic cover.
Have I missed something painfully obvious ? ABS worries me more than the cold start issue which could be the cold start device but seems strange I have 2 issues arrive at the same time
No misfiring
