dot
Evening all, in addition to the 123 I’ve recently got hold of a 1991 300TE. It’s been pretty well looked after, but I have taken it on with a couple of issues. I’ve decided to post here instead of the electrical section, forgive me if that‘s incorrect. M103 engine I think.
When I fire her up from either cold or warm i wouldn’t say she struggles to start because she always does, but it’s a slight hesitancy followed by an engine sound that possibly says she ain’t firing on all 6, but as soon as I rev the engine within a second she sounds sweet as.
Whether connected or not, this happens too while out and about. I should say at this point the previous owner has fitted a new accelerator cable and has played about a little with the adjustment of it thinking this is the route of the issue but I disagree.
At indiscriminate times, at standstill, at slowdown but never when driving the tickover revs fluctuate from just under 500rpm to almost 1000. When at the lower end it has cut out 3/4 times, but if I’m at standstill and I stick her in neutral the revs return to normal idle, but could also fluctuate after sitting there a while.
Any ideas anyone?
Dot
Any ideas anyone?
Dot
