chefdeville
- Jun 18, 2014
My 1997 W140 S320 has now covered 68000 miles from new. In December I took it on a trip to the UK from the SW of France covering over 1000km.
It broke down on the M4. I thought it was the fan belt running p/s and water pump. It turned out that whatever holds the external crankshaft pulley in place had failed leaving the pulley free to eat the crankshaft shank.
It would seem the only permanent repair would be to remove the engine and replace the crank.
My question is: is this a common problem with this engine (which was widely used throughout the range of most M-Bs at that time?) I know I had it in an E Class convertible twenty years ago without issues.
If so, would it be likely to happen at such a (relatively) low mileage and should a service pick it up before it caused mainstream damage?
