dddooommm
W164 Om642 strange fault code?
"Front SAM 905D circuit 15 relay open"
I'm working on the wife's car and managed to clear and or fix all electrical faults over the years except the one on the front SAM unit.
The fault is Front SAM- 905D circuit 15 relay open.
Her car is a 2007 ML W164 with the V6 OM642.
I'm using two different diagnostic systems that bring up this fault code but it will not clear. (Delphi and Icarsoft MBII)
I've searched multiple online areas about the 905D circuit 15 and there is very limited material on it.
F58kH is mentioned and talks about it starting the starter relay coil.
Relay 'H' in the front fuse box relates to the front SAM's circuit 15. I've swapped out this relay yet the gremlin still persists? The front SAM looks healthy with no signs of moisture.
Has anyone come across this fault before or thinks how they know I could resolve it ?
