JonathanC250
Afternoon everyone,
Some of you may remember I was having problems with my car before, that I thought was down to the gearbox. Turns out it wasn’t that, it was the EGR system, which I was suprised by, as I had recently had the car mapped and the egr supposedly deleted.
To try and cut a very long story short, I took the car back to the garage who mapped it, and they said the egr needed to be physically blanked, so I took the car away again and fitted a blanking kit, this made the engine light come on and store a code of insufficient egr flow or words to that effect. So I took it back to them again, they said they would re-do the remap, which they did, I went to pick the car up later, and the car would start, run for about 30 seconds then cut out. Turns out they had killed the ecu, as this time they had removed the ecu and opened it up to do the remap.
Anyway, they have supplied a second hand ecu, carried out the map, and I went to pick it up, and everything seemed ok, no lights on, engine didn’t cut out. It was only when driving to work the next day I noticed a slight power cut when you put your foot down, very similar to if the traction control kicks in and it limits the power. Which I thought maybe it could be that, although the traction light wasn’t blinking. Fast forward to about a week later, driving to work and the car suddenly dies, so I have to coast to the side of the road. Switched the ignition off, restarted the car and it was all ok again, no lights on.
Same thing happened on the way home that night, and the next day on the way to work, and then twice on the way home that night. Still no engine light though. So I plugged my computer into the car to see if there were any codes, there was, 2199 fuel quantity control short to ground, and p0003. I checked the plug and wires as best as I could, correct voltage at the harness, but try and test resistance at the plug, the car cuts out.
So what I ended up doing was leaving the fuel quantity control valve connection off, so that way I could drive the car without it cutting out, albeit in limp mode.
I ordered a new fqcv and fitted that and there is no change. Before I removed the old one and fitted the new one, I plugged it back in and tried to start the car, it wouldn’t start, now the short was a permanent fault where as before it was intermittent. Once I fitted the new valve, exactly the same.
Is there a known failure of the harness on these cars? As I can’t see any damaged casing or wires anywhere in the engine bay, and I don’t want to start cutting all the protection off incase that opens another can of worms!
what are the chances this second ecu is damaged? this has turned into a complete nightmare. The garage are not returning my calls or emails now, they told me there is no warranty on the work they’ve done, when I last picked the car up from there!
Sorry for the long post, this is driving me mad now!
If any of you know of anything else I can do or check, please let me know.
Thanks,
Jon
Thanks,
Jon
