220problem
I haven't posted many issues on here, but i'll get straight to the point.
I have recently started to experience some issues with my w204 C220 - 140K on the clock (motorway mileage)
Over the year I have had, DPF cleaned, DPF sensor, new EGR Valve, transmission mount, oil mount and most recently new water pump which has been great for the past 10k miles and now the latest new thermostat housing.
Symptoms before new Thermostat housing; temperature on the dashboard fluctuates bouncing up and down, it would only go up to 90 never higher but hovers around 80, but frequently sits at 40 and 0 for a few seconds when driving on the motorway. Jumps into limp mode on hard acceleration around 60mph+ on high revs.
Heating set at fan speed 4 and 21 degrees.
Symptoms after new Thermostat housing installed; driving on the motorway and temperature was good for 10 mins on 90 then slightly dropped to 80 mark and then bounces to 40 and 0 and then when stationary sits at about 40 and 80 again. After a 20 mile drive no limp mode which I was pleased about.
Heat from the fans blows a heavy load of hot air than it feels cooler for a bit and then the hot air again.
I've spent so much money on this car with all the engine management lights and limp modes, that I am now asking for help. I can't afford to keep going to the mechanic and when he scans through STAR nothing appears, and its all working fine.
What could be causing this temperature and heat shooting out?
Thanks for everyone's input.
