MBLOVERMCR
Hi everyone,
I have a 2013 c220cdi manual gearbox - 105k miles, mostly motorway at 65-75.
I’ve been struggling with a loss of power since August last year. The issue happens when I put my foot down in 6th gear and the engine moves through 2,000 - 3,500+rpm. You know yourself when something is not quite right and there’s a bit of a flat spot somewhere in that range; if I keep my foot down past 3,500rpm the car goes into limp mode.
So far I have had the actuator and both intercooler hoses replaced but the problem persists. The car is serviced each year and is looked after. It just does a lot of miles on the motorway and I set the speed limiter to 65-75.
My gut tells me it’s something to do with the turbo unit. Maybe it isn’t regulating properly and there’s a boost issue which the ecu doesn’t like?
I drive in Europe (Germany) a few times each year so it would be nice if I could floor it in 6th without the engine failing. Here in England, driving every day, I’m terrified of the accelerator pedal at the minute. I love the car and don’t want to get rid but the garages I’ve used have been tinkering for 6 months and not diagnosed it.
Maybe one of you can help? Sometimes it’s about asking the right questions as well, which I don’t think the garage is doing.
The garage say there is only a boost fault showing on the machine but when the turbo is tested the boost levels are consistent.
Does anyone have any ideas what it could be or how to diagnose the fault?
