Evening all. My Comand unit appears to be dead and requires replacement, I posted here a few days ago and the info I've been given is that it may have suffered an internal memory component failure, hence it's reluctance to boot. I've ordered a replacement unit off eBay with the same part number as mine. I believe I will need an anti theft code for the unit, I'm fairly confident I can obtain that. My question is, if I were to obtain the correct anti theft code, can I install the unit and input the code myself on the unit and it will then just work? Or, are there some additional coding steps required with something like Xentry or Vediamo etc?
I came across a YouTube video of a guy inputting anti theft codes into the comand units' directly via the controller in the car but it didn't show exactly how he was doing it.
Thanks in advance
Thanks in advance
