W204 no ignition no start
akiiraja96
Manchester
C class w204
Hi there,
C200 cdi 2011 blue efficiency se
Drove the car home, parked up for couple of hours and went to start, no ignition and no crank. Tried with jump leads but same problem
Any advice would be appreciated.
Hi there,
Sounds like the common ESL failure, it's steering lock that fails
So what work needs to be done? Thanks
First of all you need someone with xentry to confirm it's the fault with steering lock, if it is then new steering lock or emulator can be replaced
