James15678
Hi all,
I have a w205 with this issue:
Ac on drivers side will blow cold if fan speed is set to less than speed 4, at about 8⁰, once fan speed goes higher so does the temperature at the vents, up to about 20⁰. The passenger side is roughly always 10⁰ hotter.
I have no fault codes and all live data is within parameters.
Ac clutch is engaging and doesn't stop when fan speed is increased, radiator fan is not constantly running unless ac is on.
Live data shows ac pressure sensor at 5 bar before engine is started and raises to approx 9 bar when ac is on. I took it to a garage to have air con pressure checked and they said it was all OK.
Any help would be appreciated
