W205 washer parts
dwr123
C250
Does anynoe know what the part that connects the washer pump to the washer pipes is called and where i can get one online?
It fits directly onto the pump and It has a 2 wire plug going to it. I managed to snap to connector to the pump off whilst cleaning out the filter on the tank.
Another question is what does it actually do?
David
Have a look here. www.realoem.com.
Ignore the BMW bit as you can select other makes.
You can search via VIN to make sure it's the right vehicle or just select the vehicle you want.
Hi. Thanks for the link. I cannot see the specific part i am looking for. I now believe it is related to the heated nozzles. The tube to the nozzle from the pump have thin wires inside which eminate from this unit. The plug is shown on the parts diagram but not the unit that i can see. Data card say model is 205-008 with option 875 heated screen wash system. I may have to wait till the dealer opens to identify the part unless someone knows what its called
Thanks David
Some of this parts?
