W208 coupe and cabriolet doors
Kent
2000 clk 230 Kompressor
Coupe and cabriolet doors w208
Are coupe and cabriolet doors the same size and interchangeable as I need a right hand door due wind door strap broke and has bent window runner inside door or is it possible to fix please help or anyone have a silver coupe drivers door any help appreciated 👍🏻👌🏻
Hello, yes they are the same between coupe/convertible.
The window runners are available separately, but only on the back section.
the check strap is also available separately, so maybe you can make good with some bits?
Hi thx for your reply the runner looks like it is welded inside door frame
