W211 E55 battery/electronics question
London
E55
Hi all, hoping someone has a suggestion.
The battery on my W211 E55 is dead again- no worries, I have a spare. Swapped over - there were some sparks which is unusual- and as soon as I connected the negative the alarm went off with a constant tone, opened the door manually and put key in, dash is dead.
Had to disconnect it as it’s so loud. Has anyone experienced this and has a solution? Has it blown a fuse or fried something? Many thanks.
Hi, my battery drain was due to the seat module. But I did encounter an alarm going off when I took out one of the fuses in the panel on the driver side. Could check the fuses in there to see if any are blown.
Fairly big current drain or something left on if larger than expected sparks. Not had a problem with the alarm when replacing either battery on our W211. could be the alarm unit. A day going through the fuses with an ammeter might highlight the current drain.. does everything work or is something a bit “iffy”, suspect.
