W211 fault code 2075-9
whitefang
e320 cdi, 525tds bmw,
Hi all, good morning.
I plug a w211 into a gernic scan tool. ( Not star)
It came with a code 2075-9 ..
Check system high pressure control.
Max pressure exceeded via quantity control valve.
Am I correct to say this is the fault on the rail at the beginning / part on the rail closest to the headlights, & not the bulk head.
Thanks all.
Sorry, car is w211 E220 CDI 150bhp. O7 plate.
Hi all.
I just read my own thread, & cross checked a rail.
I found not sure if was a mb rail or a xx rail,but I seen ...
1 end by the bulk head is a ,rail pressure valve.
The other end at the head light side you have a, fuel pressure sensor.
From or on the hp pump is another a, quantity control valve.
I'm correct,? Please confirm / put us right.
If as I opened the thread 1st post, via quantity control valve, would this be my problem part.?
I presume the pump as this quantity control valve on...
The sensor is unlikely, s no code come back, & the rail pressure valve is unlikely aswell,.?
Ideas please...
Thanks a lot.
